주요 콘텐츠로 건너뛰기
iMac G4에 대한 수리 정보.
130 질문 전체 보기
iMac G4 neck opening tool
Hi guys,
I am looking for a tool (or the best work-around) for opening the screws of the iMac G4 silver neck. I have opened it before with screwdrivers and bits, but it was a real pain and I would love a solid tool for doing it again.
Thank you,
Lucas
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
@lucaswars2 - What are you trying to do?
I don't remember needing to take the neck apart for any repairs.
@danj It’s not traveling smoothly anymore and I’m trying to see if I can clean the inside up a bit or put a new plastic bracket in to make it smoother...
댓글 달기
답변 1개
Apple doesn’t offer the sub components that makes up the neck. Here’s one source for the needed part:
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thanks, but I don't need a replacement part, I just need a tool to open the neck with...
In that case you'll need to make a custom tool. A piece of brass rod should do it drill the three holes into the brass rod (handle) and using some steel pins of the correct diameter press fitted should do the trick.
댓글 달기
귀하의 답변을 추가하세요
Lucas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 362
