주요 콘텐츠로 건너뛰기
Repair guides and support for Compaq laptops produced by the parent company, HP.
134 질문 전체 보기
My laptop connects to my phone's Wi-Fi zone but not to my house Wi-Fi
It's a Compaq CQ45 Windows 8 but I just updated it to Windows 10 to see if that could fix the internet problem but it didn't. Sometimes I get to connect the laptop to the Wi-Fi but it's really weak and it often disconnects very soon. But it easily can connects to my phone's Wi-Fi zone without any problem. In other laptops the Wi-Fi works well.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Bea uwu
there are some ways to try,
On the device manager, what is the manufacturer and model of the wifi card?
  1. try updating the wifi drivers manually.
# check if the antenna cable is connected properly to the wifi card
  1. if you have a spare wifi card, swap and see if it works.
  2. if the signal is still bad with the swapped wifi card, there is a possibility the internal antenna could be faulty.
you may follow the below guide, page 7 for the wifi card location
http://h10032.www1.hp.com/ctg/Manual/c01...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi,
To add to the answer place the as close as possible to the WiFi router and check if the connection holds.
If it does this usually points to an antenna problem.
I'm thinking that the phone is a lot closer to the laptop when you tried this than the WiFi router was ;-)
댓글 달기
귀하의 답변을 추가하세요
Bea uwu 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 47
