주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S6 Edge+는 Galaxy S6 Edge 스마트폰의 커진 버전입니다.
Why wont it turn on?
my samsung hasnt been able to turn on when i left it charging and woke up in the morning. I have tried everything such as holding the 3 buttons and nothing has happened. it would only stay on 0% battery icon and do nothing, i have booted in recovery mode then it would shut off instantly and go on 0% again. then after it went tonot turning on at all. i replcaed battery and left it charging and nothing too.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Does the charging icon appear though?
If not, maybe it's the charging port.
I am assuming you checked your charger already.
댓글 달기
답변 1개
Try using a wireless charger to see what’s up. If it charges just fine, try using the cable. If it doesn’t take a charge on the cable, it’s most likely the charge port, which is a common failure on devices with MicroUSB. The bad news is if it is the charge port that’s bad, you’ll need to replace the screen as well because the two buttons on the side of the home button are part of the port assembly and go under the screen. Unless you can find someone who’s good at microsoldering they can replace it.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mike Hawk 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 22
전체 시간: 336
