주요 콘텐츠로 건너뛰기
A 17 inch laptop equipped with an Intel Core i7 CPU.
4 질문 전체 보기
Laptop won't come on if unplugged
Display is showing full charge but won’t come on if it’s unplugged. Does the battery need to be replaced?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi,
If your laptop is no longer holding a charge for long periods of time or always needs to be plugged into a power source to work, use this Lenovo IdeaPad U530 Touch Does Not Hold Charge problem page for possible causes and solutions.
If Windows10 is installed, create a Win10 battery report to check the condition of the battery.
It may be that even though it shows that it is fully charged, it may not be able to supply the necessary power when under load.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks so much for the help!
댓글 달기
Yea, the battery is done. Go ahead and replace it cuz it holds no charge at all.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Even though the display shows a full battery?
댓글 달기
귀하의 답변을 추가하세요
cindylulu15908 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 173
