주요 콘텐츠로 건너뛰기
Google의 2세대 Pixel XL은 모서리가 둥근 6인치 P-OLED 디스플레이를 자랑합니다. 64GB 및 128GB 스토리지 구성과 두 가지 색상으로 제공됩니다: 저스트 블랙과 블랙 앤 화이트. 2017년 10월 19일 출시되었습니다.
Requirements for phone to power on
My pixel repair isn't going according to plan, so I am troubleshooting.
1.) Can the phone power up without the shield above the logic board? Also, what about the screws. Do they serve any conductive/grounding purpose?
2.) Can the phone power up with no display?
3.) Can the phone power up with no battery? (I.e, USB cable only, and battery disconnected?)
4.) What components can the phone function without? (I.e, if I had to do a trial/error teardown, are any components essential to the phone powering up?)
5.) The logic board seems to have multimeter contact points. Can this be used for proper testing? (I have a multimeter)
Thank you in advance!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I have not worked on a google pixel before but here’s what I found out from working on other phones:
  1. That shield probably doesn’t do anything, and I haven’t seen a screw that is conductive, I doubt the pixel has one
  2. Yes, but you won’t be able to see anything
  3. Usually phones boot loop if you don’t have a battery connected
  4. Logic board, battery, charging board (you could use the power button instead, although I did this on an iPhone 11 and it wouldn’t turn on)
  5. I have no idea, I have never used a multimeter
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Logic Islife 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 8
전체 시간: 387
