주요 콘텐츠로 건너뛰기
모델 A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
Is it possible to upgrade the motherboard/CPU/RAM?
I have had this iMac for about 5 years at this point and I would like to upgrade it as it is getting slow. Apparently it is very difficult to upgrade, thus I want to ask, is it possible at all to upgrade the CPU, logic board or RAM on this computer and is it worth the effort?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Sorry Apple sometimes makes orphan systems ones which are the only one in a series. Intel is the root issue here as they brought out a few odd ball CPU’s as they needed something to fill the void of not offering the 10 nm chips they were expected to deliver!
So here is the different series Apple intro’d around that time:
Note the Family ID (last value in the description) is different between each. You can’t swap out the CPU’s as each one uses a different micro code (Haswell Vs Broadwell) which is held in the EFI (that’s typical for Apple). Replacing the logic board would be the only option but again Apple makes it hard! There are differences with the display connections between the (iMac16,1 Vs iMac16,2)
Here’s an example where Apple used the same Family ID across very different logic boards iMac16,2 Here Apple used the same CPU series across multiple systems (same micro code) but different logic boards & displays!
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
Thanks for the info
@Mark - Don't forget to score the answer and accept it - Sorry I couldn't offer you something better.
Look at boosting the RAM and getting a SSD Vs HDD or Fusion Drive (which are slower)
댓글 달기
답변을 추가하세요
Mark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 663
