주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.4GHz, 2.7GHz, 또는 2.8GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
My New Battery upon input is making Sparks?
So, I recently purchased a new macbook battery, and removed the old one with ease. After using the adhesive to remove glue and the like, I also added some alcohol to wipe the area and clean up any additional adhesive.
When I went to put the new battery in, I pressed the connector onto the board and while trying to lightly put the cells into place, I noticed a few sparks on the right side of the battery - I immediately stopped. A small cloud of smoke could be seen as well.
I let everything dry, and did not expect this to happen, could it be a faulty battery? Did I install the battery wrong? I figured the new one should not be doing this at all. I’m wondering if I let the battery discharge (how would I do that safely?) I could just come back to it and move it around.
What should I do to continue the installation, ( I haven’t even screwed the screws back in for the battery)?
Thanks for any assistance :)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Where did you buy the battery?
@danj Right here at good 'ole Ifixit. The battery ended up not sparking anymore. But, as I tried to lightly press it down so the adhesive would stick to the bottom of the laptop I noticed fumes and the cell I had my hand on became very hot. So I stopped. Will probably just ask for a replacement.
Yes! That makes sense!
댓글 달기
답변 1개
선택된 해법
usually sparks/smoke from these batteries come from punctures and the layers of the battery reacting with each other. If something conductive, like metal, is bridging the layers you will get that reaction as well.
Its probably best to get another battery as that one is a potential fire hazard, and could damage your laptop as well in the future.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Sal Elosa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 525
