주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GameCube는 Nintendo의 네 번째 가정용 게임기입니다. 수리는 간단하며 일반적인 수리 도구만 있으면 됩니다.
Console will not read a clean disc
I’ve had this gamecube for a while now and it’s never given me an issue. The other day, however, I picked up a copy of Super Smash Bros Melee that has issues. It will load up to certain points and then give me the “disc could not be read” message. opening and closing the tray like 15 times allows me to get to the next portion of the game where I encounter the same problem. the disc looked super clean but I had it buffed at a local game store anyway and still get the same results. I have already adjusted the laser POT (160 ohms) and still nothing. again, I can play any other game fine but Melee is incredibly difficult to get anything out of.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Is the laser lens dirty? And does the disc appear to be "rotting"? If it seems to be "rotting", you might need a new copy. I would try it with a different copy of the same game and see what happens. If it works on a different copy, it's probably the disc.
Here's another idea: If you have a functional original model Wii (RVL-001) handy, try putting your disc in that and see if it works. That might give you a better idea as to whether it's the GameCube or the disc.
댓글 달기
답변 1개
가장 유용한 답변
Hi!
As other games work, I would leave the Gamecube as it is. It's probably related to the disc... I would get yourself a new copy of the game and see if it works then.
It's most likely related to the game. How clean it looks wouldn't say anything, it could be a super small scratch which is hard to see on the top side or bottom side causing it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Curtis Trendler 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 248
