주요 콘텐츠로 건너뛰기
Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97 질문 전체 보기
Replaced damaged display but nothing shows up
I replaced the damaged LCD display with one from iFIxit but when I turn on the iPod it shows nothing on the display. The backlight works; I can hear the drive spinning; and I can play songs but no menu or song info shows on the display. I'm going to try retracing my steps and making sure that all connectors are on solid. Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I highly doubt resetting would work here.
Yes, resetting the iPod didn't help; both before and after reinstalling the display. I've asked ifixit support for help.
댓글 달기
That sounds good, open it back up and try reinstalling the display.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Unfortunately, that didn't help.
댓글 달기
귀하의 답변을 추가하세요
russtoku 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 6
전체 시간: 1,321
