주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
1185 질문 전체 보기
MacBook fan spins fast but won't turn on
The fan only spins when I hold the power button for 10secs and connect MagSafe while holding the power button for another 10secs.
Have done NRAM and SMC reset, nothing happens. MagSafe shows an orange light.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Can you give us some more info on what happened. Did you drop of bang the system? Did you have a liquid spill or st it down on a wet surface?
Thank @danj for your swift response. No liquid spill on the system. I put the system on sleep a night before with power connected all night and the next morning when I open it, it refused to come on. I tried every possible solution including SMC and NVRAM, it didn't come on.
댓글 달기
답변 1개
가장 유용한 답변
Lets try this, follow this guide MacBook Pro 13" Retina Display Early 2015 배터리 교체 just disconnecting the battery following the Steps to Step 6. Now set the system on its side so you can gain access to the keyboard with the battery connection not shorting.
With the battery and any thing else disconnected press the power button a good 10 seconds so you fully discharge the circuit. Now plug in the MagSafe did the system spontaneously restart? If it did you need a new battery!
해당 답변은 도움이 되었습니까?
점수 1
댓글 8개:
Thank @danj but have done that before but nothing happens. To save time, I observed that U7870 on the board is very hot. but according to the guide I read, it was written that a hot component is a sign of shorting, I don't know how true that is
Also, note that the fan spins when I hold the button for 10secs, then plugin MagSafe while holding the power button for another 10secs. no chime, no display, just fan spinning at high speed.
Please help, bringing this laptop back to life has a huge influence on my career
If you did exactly as I stated and the system did not spontaneously start then your logic board needs repairs or you'll need to replace it.
@danj PP1V8_S3 cannot be found on a1502 logic board 820-3536, please what is the appropriate term?
@omiran - What are you looking for? How about reviewing the schematic and board views for the given system.
댓글 3개 더보기
댓글 달기
귀하의 답변을 추가하세요
habeeb hassan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 88
