주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
Is my display original?
I purchased a used iphone X with cracked glass and no Face ID. I planned to replace with an OEM screen and could have done w/o the Face ID. But now I realize that even the true tone is missing. So is my display already a replaced one or is original? How can I make out this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
If face Id and true tone are both missing the screen has definitely been changed. Unfortunately face Id is not repairable unless you have the original parts. It sounds like they tore the cable to the proximity/floor sensor and earpiece speaker. It possibly to repair that if you can find someone with the skills. The front camera and those sensors are paired to the motherboard and if one is damaged or changed then you are out of luck. Unless you want to trade it for a refurbished one from apple and pay a few hundred dollars. But if you can find a repair shop that has the correct equipment you can get true tone back.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thank you for the answer. The rest of the phone is working well but even the auto brightness feature is missing and does not work. No 'replaced display' message in the settings as well. Just cracks on glass and dents around the earpiece area, can dropping the device cause all these issues?
It's a small possibility but the iPhone X will not show that the screen has been replaced. That feature if you want to call it that didn't start putting up that message until the iPhone XS.
댓글 달기
답변을 추가하세요
Nitesh Rathod 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 24
전체 시간: 117
