주요 콘텐츠로 건너뛰기
9월 20일 출시한 Apple의 2019년 주력 스마트폰으로 6.1" LCD 터치스크린, 이중 카메라, 그리고 여섯 가지 색상으로 제공합니다. iPhone XR의 후속 제품입니다.
No service on my iPhone
I recenty bought an almost unused iPhone 11 that had a screen issue. I changed the screen myself and everything seemed to work workperfectly when I assembled it together.
The only issue i’m having is that my iPhone keeps saying no service. it may have one dot for maybe 5 seconds when turning flight mode on/off or when I reboot the device, but after 10 seconds or so it says no service. In cellular settings I can confirm it is the right network, and it reads the sim. I get asked for the pin code when putting it in.
I have also tried another SIM card in my device and its still the same issue. I tried using my sim on my older phone, and it works in that device.
So i’m guessing it is a hardware issue or something like that. Please help! Thanks in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 5개
Since it is asking for a sim pin, the device is “locked” (not actually, but functionally) from your network. If you have Sprint (or I guess TMobile now) your sim needs to be “activated” for that device on their end.
You can do this from the website in many cases as long as you can provide the imei number and the number from the SIM card.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Have the same issue here on my recently purchased 11. No carrier lock on the phone but it only accepts one network (Cell C) other sims register but show no service with symptoms listed above. IMEI has not been blacklisted. Can anyone help?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the same problem, i need help to
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I will try to replace the SIM reader and I will send to you the feedback.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Şebekede sorun yaşıyorum yüksek internet gerektiren uygulamalarda çok fazla gecikme ve ping yaşıyor kullanamıyorum aynı sim kartı ve aynı telefona sahip herkes kullababiliyorken ben kullanamıyorum.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mathias Fadnes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 714
