I have a De’Longhi all in one machine model # Bco 330T
The coffee maker portion of the machine is not heating up, I don’t hear the coil heating the water. The espresso maker portion works fine is this repairable?
좋은 질문 입니까?
좋은 질문 입니까?
After doing some research, apparently this is a common issue with this brand. So, there is a central heating plate that heats the water for the espresso side and brewing side. The thermostat on the plate goes out and thermostat fuse gets blown. I will link a YouTube repair video below that explains this. Even though the model is a little bit different, it will be the same concept. I hope this helps. DeLonghi BCO430 Coffee Maker *WON'T BREW* *FIXED*
I apologize, the video has a model with a separate plate for the brewing side. This is why I felt it would be the most helpful for you.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 8
30일 전: 33
전체 시간: 1,047
@pchris330 - If you need to make corrections go to the Options tab to make the edit or if you need to add information you can also create a new Answer entry when you save it will ask you if you want to post as an update.
Dan 의
