주요 콘텐츠로 건너뛰기
The HTC 7 Surround is a smartphone created by HTC running on the Windows Phone operating system.
7 질문 전체 보기
screen wount go past htc load screen hwat should I do
i had the phone on one day but it was messing up and wouldn't show my pictures so i turned it off and back on and i wont go past the htc screen. i called at&t and htc for help but thaty said its nothing they can do since i brought the phone on ebay. i hadn't even had it for a month yet an im inlove wit the phone plz help!!!!!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
선택된 해법
Thanks for posting your problem. I have just fixed this problem on a customer's Phone. You will need to replace the MicroSDHC card in your Phone. You will need to take apart the phone, at least partways, to do this. Here are the parts needed:
Torx 5 Screwdriver
00 Phillips Screwdriver
16GB MicroSDHC Memory Card (found here: http://goo.gl/6urM7)
As a note, the card in the Phone I was fixing was a Class 4.
You should be able to use this video as a guide to take apart the phone to where you can replace the MicroSDHC Card: (http://goo.gl/sJ5h0)
Best of Luck,
Tough Gaming Technical Support
Agent Elisha
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
+ Thanks for your help Elisha. Your help around here would be very much appreciated ;-)
댓글 달기
Unfortunately AT&T or HTC won't help being that this item was purchased as is/used and most likely is damaged. I would try to Hard Reset the HTC and see if that helps. If not, check back here for further troubleshooting.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
SD internal replacement.you also can use 32g card. (Standard sd card)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
jalisa 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,809
