Why will the bike not start?
this is a 1987 fzr 1000.It won’t start.the starter works and engine spins but it won’t fire up.there is plenty of gas.
좋은 질문입니까?
좋은 질문입니까?
I would start by spraying a little bit of starting fluid in the air intake.
Try starting the bike after spraying the starter fluid.
-If the bike starts up and then dies, then you have to check the fuel filter, clean the carburetors, and check for clogged fuel lines
-If the bike cranks over without signs of starting at all then you might have an electrical problem with your ignition system. I would check the coils on the spark plugs and the spark plugs themselves.
Good luck
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 1
지난 30일: 21
전체 시간: 1,439
댓글 1개
Have you checked your spark plugs?
Broske 의
