주요 콘텐츠로 건너뛰기
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo 프로세서
310 질문 전체 보기
Problem with startup manager on my iMac!
As the title says, when I try and boot into a starup manager to install a MacOS on a new HDD I put into an iMac it only shows white screen with cursor on it with nothing else on the screen. Any help is welcome, thanks in advance.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I think you have a deeper issue here ;-{
Are you able to boot up the system in Target Disk Mode? Press the T key when restarting. Do you see the FireWire Icon on your screen?
yes, i've tried and target disk mode works
댓글 달기
답변 1개
가장 유용한 답변
So that tells us the onboard GPU has failed!
Most likely you have the NVIDIA GeForce 9400M. You’ll need a new logic board with this version 21.5” iMac Logic Board, 3.06GHz, NVIDIA
If you have the ATI Radeon HD 4670 model, you’re in luck! As this version has the MXM graphics board 21.5” iMac ATI Radeon HD 4670 GPU board
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
woow, really, there is no other possible problem than dead gpu?
Do you still have the Grey CD/DVD Disks that came with the system? If you do you could try running diagnostics.
댓글 달기
귀하의 답변을 추가하세요
Uros Rajkovic 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 46
