iPad 7 LCD Screen Digitizer - Protective cover for Inside?
I am working on replacing an iPad 7 screen using iPad 7/8 Screen Digitizer
The problem is the cables were taped inside, but I see no protective cover on the inside glass. This left residue that is quite difficult to clean. I only see two protective strips, one at the top and one at the bottom that are big enough to cover the borders for the home button and camera.
There are blatant red tabs to remove the protective cover on the front of the glass and the two inside pieces at the top and bottom. Am I missing something or is this how the part comes?
좋은 질문 입니까?
댓글 1개
Too add on to my problem. I see the circle of black dots in the corner (in the 2nd picture with the red tabs the circle in the bottom right corner) is not part of the front protective film/cover. Is this on a protective film/covering on the inside or is it part of the replacement screen?
The red tabs (as in the 2nd picture of the part) only peel off the sections at the top and bottom; those pieces are only as tall as the red tabs.
*edit* Had stated it was the 3rd picture. Actual picture is 2nd picture with the red tabs.
Wesley Simkins 의
