주요 콘텐츠로 건너뛰기
iMac G4에 대한 수리 정보.
130 질문 전체 보기
My iMac G4 screen is not straight
Is there a way to straighten the display. Mine is slightly sagging downward on the right hand side of the display.
The screen is not tight and can be wiggled left and right
Notice the wiggle room on the top hinge of the arm.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Is the mount loose?
Post a pic or two so we can see clearly the defect. Use a ruler if that helps 기존 질문에 이미지 추가하기
Hi Dan, I have added some photos and tried to describe the issue in greater detail.
댓글 달기
답변 1개
선택된 답변
So the mount is loose! There is a set of nylon washers which wear out so the joints flex. You’ll need to take the mount apart which is a bit of a task! You’ll need a set of special tools from these folks iMac G4 neck disassembly tools (for the proprietary 3-prong screws, custom designed and 3D printed) if they still have them or you’ll need to make your own.
After taking the neck off and opened up you’ll see the washers. This is the hard part as you’ll need to find something that you can fit in to replace the worn washers.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Pieter Hartzenberg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 495
