주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1502 질문 전체 보기
3gs Static From Speaker, Then Reboots
Ok I have a 3gs 16gb that the sound is randomly cutting out. I get a loud static sound from speaker and then the sound cuts out. The phone then either reboots or just has no sound from speaker,mic, or earpiece. When I make a phone call the phone will connect but I cant hear them and they cant hear me.
I have since restored phone to factory and the phone still made same noise and reboot itself. I have updated software to latest version 4.3.5 but was occurring on 4.3.3 as well. I have opened phone to check connection of ribbon cables and all appear to be good. I checked for the two capacitors above the #4 cable and they dont appear damaged.
I've seen multiple posts with similar problems but no answers. As far as phone being opened replaced battery about 9 months earlier and had no problems with phone till recently. Phone was not dropped or wet. Thanks in advance, Steve
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
Ordered up a flex cable and dock connector I'm hoping that will solve the problem.
Installed new flex connector and dock connector and phone seems to be working fine. Flex cable is a PITA to replace.
댓글 달기
답변 3개
선택된 답변
I do not know the answer to this multifactor problem, both speakers, sound, mic, shutdown etc. Most likely Logic Board. But some of the strangest problems of 3GS occur when the Flex Cable #3 is damaged or not inserted correctly (shorting system). I doubt this is the problem, but if you have the time and skill set, maybe replace #3. If it works great, if not, I warned you it was an out in left field long shot. If you decide to proceed before opening and during 3GS repair, make sure iPhone is OFF.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have the same problem. So you sure the dock connector replacement fixed the mic, headphone jack, speaker issue?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I currently have the same problem. I changed the dock connector but didn't work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
steve 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 5
전체 시간: 1,455
