주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple이 2019년 3월에 출시한 새로운 iPad Air 태블릿, A12 Bionic 프로세서와 10.5" 스크린을 자랑합니다.
Screen White Pressure Point
Ive been seeing this white spot on my screen, and the reps at Best Buy said it was a pressure point on the screen. I tried using a small vacuum pump to try and pull the screen back up from that spot, but it hasn’t fixed it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Best Buy Geek Squad really doesn’t know much about repair other than selling a solution. That white spot could be a couple things like a pressure point if the frame was bent or the battery swelling, although that doesn’t seem likely as that tablet came out just last year. It could also be a defective LCD.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Any thoughts on how I could possibly fix it? Everything else works fine. Just that the spot itself is right there in my line of sight and what I’ve tried so far doesn’t work
@ibsinrg you'll have to take it apart to find out what's wrong with it before you can fix it. I would start by taking the screen off but be very careful. The glass is fused to the LCD, so if you damage the glass or LCD, you'll need to buy a whole new screen assembly. Follow the ifixit guides to take it apart.
댓글 달기
답변을 추가하세요
Russell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 31
전체 시간: 1,429
