My iPhone cant turn on
my i phone cant turn on even
my laptop also cannot detect this even i plugged in it for many times..
and when i'm trying to charges my iphone
the cover become hot
why?
why all this happen
help me pliz
좋은 질문 입니까?
why?
why all this happen
help me pliz
좋은 질문 입니까?
It SOUNDS like a dead battery. Lithium polymer batteries degradation is exponential...when they start to fail, they fail fast. Your phone getting hot is probably an indication that the charging circuitry over working itself to charge the bad battery, and may also be the battery getting hot from resisting charging. Try replacing the battery first and be sure to replace with only a 3GS battery, iPhone 3G batteries will not work.
해당 답변은 도움이 되었습니까?
ill try it after dis..how about problem which iphone cant be detect by laptop..is that also bcoz of the battery???
no power from phone=no message to computer. This is why your phone can't be detected, change the battery and it should be good. I agree with what Phillip has advised you.
Check with a torch the LCI's there is one in the headphone jack and one in the dock of the iPhone, there is also two inside if you can open the phone. They go red when wet
해당 답변은 도움이 되었습니까?
can u xplain a little bit..i get confuse with ur instruction..
wat u mean by they go red when wet?
I believe what Paul is referring to, are the LCI, liquid contact indicator. they are normally white but turn red whenever the device is exposed to liquids, i.e. water damage.
ok..ill try to check it up..
Same probs here, i have a iphone 3gs 6.1.3 and trye to hackivate it with redsn0w, (its lock on Orange France)under the prosess it turns off and now its dead. The battery is full. Nothing i happening when i conect it to my Mac or charge...please help me
Bjorn
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,442
댓글 2개
any drop or water damage? any problems with charging or crashing phone before this?
pollytintop 의
no i take care my i phone carefully..but then i got there was a day where my iphone lack of battery and when i tried to charger my iphone..the screen..keep blinking and then it turn dark..
after that i cant charger my iphone anymore..whenever i charger it..it turn hot..and my laptop also cannot detect my iphone..
any idea?
hanif khair 의
