How to fix a loose right stick?
In your guide, you show how to replace the right stick. but how to fix it if its loose and it doesn’t go back to neutral position automatically after moving.
좋은 질문입니까?
좋은 질문입니까?
It depends on why it’s loose. If it’s loose because of the internal parts of the module, likely a new module is in order. If it’s loose because the plastic thumb stick cap has cracked at the connection replace the plastic part. If it’s loose because the thumbstick cap is just worn out, you could try opening it up, pop off the thumbstick cap, add a thin layer of something (tape or whatever) to the module post, pop the thumbstick back on and see if it’s more stable. Good luck.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 1
지난 30일: 9
전체 시간: 1,292
