주요 콘텐츠로 건너뛰기
Mac Pro는 데스크톱 Mac 시리즈의 2013년 개조판으로 알려져있습니다.
117 질문 전체 보기
Mac Pro 2013 - USB port not working after CMOS battery replacement
I have a 2013 Mac Pro cylinder. I was facing issue with powering it on, after multiple tries I used to successfully make it work. Later I realized that there is a problem with the CMOS battery.
Now after replacing the CMOS battery, the unit is starting but all the 4 USB ports have stopped working.
Thunderbolt ports, HDMI port & LAN ports are working perfectly fine.
The USB is drawing the power but is unable to detect any devices including external keyboard and mouse.
I'm able to access the machine with a screen share option from my other Mac.
Under system report, this is what I'm getting
USB 2.0 Bus:
  • Host Controller Driver: AppleUSBEHCIPCI
  • PCI Device ID: 0x1d26
  • PCI Revision ID: 0x0006
  • PCI Vendor ID: 0x8086
Hub:
  • Product ID: 0x0024
  • Vendor ID: 0x8087  (Intel Corporation)
  • Version: 0.00
  • Speed: Up to 480 Mb/s
  • Location ID: 0x1d100000 / 1
  • Current Available (mA): 500
  • Current Required (mA): 0
  • Extra Operating Current (mA): 0
  • Built-In: Yes
BRCM20702 Hub:
  • Product ID: 0x4500
  • Vendor ID: 0x0a5c  (Broadcom Corp.)
  • Version: 1.00
  • Manufacturer: Apple Inc.
  • Location ID: 0x1d110000
Bluetooth USB Host Controller:
  • Product ID: 0x828d
  • Vendor ID: 0x05ac (Apple Inc.)
  • Version: 1.50
  • Location ID: 0x1d113000
Can someone please help me with this
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
What does a USB power meter tell you? USB Mini Voltmeter
댓글 달기
답변 1개
가장 유용한 답변
I’m suspecting the IO board data cable maybe not making contact on one or more pins. Go back to Step 16 here Mac Pro Late 2013 CMOS 배터리 교체하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I again dissembled the whole thing and fitted everything back again properly, still no luck.
I used the app "Ampere" on my phone to check the current flow.
It's showing around 510mA & 3.7V
All you've proved is the USB ports power services are working. We still don't know if the data lines are working.
댓글 달기
귀하의 답변을 추가하세요
Hash 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 386
