Is there a TOGGLE SWITCH that can be used on an iPad AIR (3rd gen)?
I'm searching for a TOGGLE SWITCH that can be used on an iPad AIR (3rd generation) OR a CASE that includes a large toggle switch (an adaptation for an elderly person). Any suggestions? Thanks!
Update (08/28/2020)
I recently purchased an iPad Air third generation for my 89-year-old mother from the Apple Store.
She is learning how to use it. However, the volume switch which is located on the upper right outer edge of the iPad is not only very small but also very difficult for her to use. It has one small rectangular button for increasing the volume. And just below it, it has one very small rectangular button below it for decreasing the volume.
She not only has a hard time to find and see these two little buttons (that are no more than ½ inch in length each) but also to manipulate them with her old fingers.
I hope to find a toggle switch which could be attached / stuck over the volume buttons that could elongate those two volume buttons. If it elongates the up button, the button would give more space for her to press the INCREASE VOLUME part of the buttons, or give her more space to press the DECREASE VOLUME button.
Sadly, SIRI and placing the volume on the iPad Air’s front screen didn’t work for her.
좋은 질문 입니까?
Can you explain a bit more here. What switch are you trying to add or alter?
Dan 의
Define “toggle switch” please
Dylan Devries 의
