주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Baseband CPU shortened (U_BB_RF)
Hi,
I was repairing a water damaged iphone 6 when i removed the short on PP_VCC_MAIN, i restored it because of the passcode on it. After restoring i noticed that i couldn’t activate the phone, so i discovered a short on VREG_SMPS1_0v90 and when i removed the baseband cpu, the short was gone. How can i repair it or bypass activation ? thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
There is not much you can do if the short is in the baseband IC itself. What you can try is to inject voltage into that line or pad on the IC. This sometimes burns the short out, at this stage you have nothing to lose.
해당 답변은 도움이 되었습니까?
점수 3
댓글 6개:
Ok. So how much voltage i should inject in ? also it's impossible to buy a new one ? Thanks
@anthony10006 No the baseband CPU cannot be replaced as it is married to the CPU. You will need to get the short out to have a working phone.
I don’t know how much voltage you should inject. Usually if a 4V circuit has a short and you inject 4V into it only 1 or 2 volts might be going into the shorted component. You should start with 1V and increase as needed. This method doesn’t have a good success rate but as I said you have nothing to lose.
Okay I’m gonna test this thanks
well i injected more than 16 v and the short is still there even after reballing :/
@anthony10006 As I said, this method doesn’t have a good success rate. Unfortunately there is nothing else you can do .
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Correia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 333
