주요 콘텐츠로 건너뛰기
Slim, lightweight and stylish, the Swift 3 is the ideal laptop for working on the move. The latest NVIDIA® GPU, Intel® CPU and long battery life are housed inside a choice of displays: an elegantly silver chassis with a 13.5” 3:2 ratio 2256x1504 IPS VertiView Display or the vivid colors of a 14” 16:9 FHD IPS display.
20 질문 전체 보기
Acer swift sf314-54 screen removal
Hi all, I have an Acer swift sf314-54 which the screen needs replacing , however it dose not seem to be held in with screws to the back case like models before and ater it, I havent been able to find a ‘how to’ to remove it either, so dose someone have any advice on this please.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
The best advice I can pass along is to search for a service manual. This should have disassembly instructions.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This model's LCD screen is attached to the cover with Double-sided tape, you will need a hair dryer to heat up the edge then use LCD pry tool to slowly peel off the tape.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
colin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 7
지난 30일: 24
전체 시간: 1,963
