주요 콘텐츠로 건너뛰기
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo 프로세서
310 질문 전체 보기
Fan running in full speed
I got this imac from a friend, the original problem was that not power at all, so i made all the diagnostic suggested in the service manual and i concluded that i have to change the logic board, and i did it, now the status is the following with the good logic board:
When i plug the ac cable…
1- Led #1 is on
2- When i press the power button Led #2 flicker for less than 1 second and off
3- The fans start to work at full speed all of them and stay on forever jeje.
And that’s all…
I press the power button, stop for a second, and all the fans start to work again.
I change the RAM memory too for a good one and nothing happens :(
If anybody can help me with this i’ll appreciate it. Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Sounds like you got a bad logic board. Review your cable connections incase you missed one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I change it for a good one, so maybe this one have problem too?
@Gary - One of the problems with these older systems is finding good parts as Apple has long since stopped offering new parts, all you can find is recycled parts. Some folks don't make the effort to test the part before they sell it so its possible you got a bad one.
Thanks you Dan i'll find the way to get a good one!
댓글 달기
귀하의 답변을 추가하세요
Gary 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 65
