주요 콘텐츠로 건너뛰기
MacBook Air 11"의 2014년 4월 업데이트는 새로운 듀얼-코어 i5 및 i7 Haswell 프로세서를 장착하고 배터리 성능을 약간 향상하였습니다.
100 질문 전체 보기
How to retrieve data?
My 2014 Macbook Air is completely dead and won’t turn on. The Apple store said the problem is likely water damage to the logic board. Is there any way for me to retrieve the data from it? The Apple store recommended using a toaster but I’m not sure which models would be compatible with the hard drive. Any help would be appreciated!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Someone at the Apple Store told you to use a toaster? I wouldn't do that! Heat won't help you here.
If the system was still wet I would take it apart and carefully clean out all of the spill and you would need to likely clean off the parts with distilled water and/or 85% or better isopropyl alcohol
댓글 달기
답변 1개
선택된 답변
To recover your data you’ll first need to get a case which can hold it like this one: OWC Envoy Pro Portable, Bus-Powered USB 3.0 Storage Enclosure for select Apple Flash SSDs from most 2013 to 2015 Mac Models
Follow this guide to get the SSD out MacBook Air 11" Early 2014 SSD Replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ally H 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 105
