주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2264 질문 전체 보기
iPhone 7 randomly turns off
Hi I recently bought an cracked iPhone 7, in hopes of resseling it, note it was my first time fixing an iPhone, I bought the replacement screen, and put the bluetooth home button, the first time i encountered the problem was when I finished it all, it started turning off and then on until it drains a battery which happens really fast, it usually happens on 20% and 50%, I tought it was due to battery which was replacement one even though it was on 100% health, so i replaced it with the original one, and when it is about to turn off it becomes very hot under the rear camera, I cleaned all the connectors with PCB cleaner with awarenes of not damaging it, I also have to menition the backplate on battery and the lcd connectors has only one screw holding the backplate, also the display backplate had one bruised screw which I had to cut off and bruise that backplate side, but the display is fine.
Any help would be appreciated, thanks in advance!
Update (09/12/2020)
It was due to battery, I replaced the replacement battery with the original one, after that it shut down just once and it drained my battery from 52% to total 0, after that It didnt shut off, I can also use various apps it wont turn off, thanks everyone!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Wasn’t the bluetooth homebuttons the first working ones out on the market for iphone7/8? I dont know how reliable they are, try without the home button installed i guess.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Will try without it i noticed it didnt allow connectors to sit well
댓글 달기
귀하의 답변을 추가하세요
Em4N 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 49
