주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1864, A1897. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
678 질문 전체 보기
Super stripped pentablobes screw
I’ve tried the tape, solder, rubberband, flathead screwdriver method. nothing works and I’m getting desperate. I don’t have a screw extractor
the two screws are full circles
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
please help me
댓글 달기
답변 2개
가장 유용한 답변
What is the reason to open your iPhone ?
Does the screw turns, that means that the legs from screen have broken and that the screws won’t come out (then you can lift the screen and work from the inside), or doesn’t it turn and it stick on it’s place? Have you tried super glue? If that doesn’t help then you have to drill it out.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
my screen is broken so I need to change the screen (not cracked full dead screen). the screw doesn't turn, I'm looking for a drill bit but that's my last resort
댓글 달기
I have had this issue on multiple occasions. Even after trying all of the things you have listed and more I have found a solution which is my go-to in situations like this and has gotten me out of sticky situations multiple times.
You need to get the ifixit driver bit in a flathead size 1. I have tried so many other flathead bits without any success and this one seriously is a god sent! Even when it is completely rounded off, I have found this will remove any pentalobe with the right amount of pressure.
Can be purchased here:
Mako Driver Kit - 64 Precision Bits
Good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Ean Palacios 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 71
