주요 콘텐츠로 건너뛰기
9월 20일 출시한 Apple의 2019년 주력 스마트폰으로 6.1" LCD 터치스크린, 이중 카메라, 그리고 여섯 가지 색상으로 제공합니다. iPhone XR의 후속 제품입니다.
475 질문 전체 보기
Should FaceID work when LCD opened?
I’ve purchased iPhone 11 with cracked display - FaceID not working - sometimes showing “not available” but many times just “move higher, lower - closer iPhone message” which I think confirms it is kid-of-working.
100% crack was on cameras and whe worse half crack opened on that “mirror” thing which is in my opinion that projector - but not sure.
I just wanted to know if I should be able to test FaceID when screen opened so no cracked glass on the way.
There is something mirror on that area on display where ‘Projector’ present.
I don’t want to spend £80 on display if FaceID not working :(
I’ve tried with opened screen to activate FaceID but no success as not easy to point directly on face what cannot see what is happening on display - but normally it should even start doing scanning.
Thank You
Update (09/24/2020)
As I’ve learned from this video - “dot projector” is not cracked and “Flood illuminator” is fine - no signs of water damage
Why Face ID Not Working After Repair
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If there are any cracks in front of the sensors it can diffuse the light and cause errors. You won’t necessarily know if you can fix the issue unless you at least inspect the assembly for any damages. I know that screen can be a little pricey but even if you can’t get FaceID to work, I would imagine you got a great deal on an iPhone 11.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 30
