주요 콘텐츠로 건너뛰기
9월 20일 출시한 Apple의 2019년 주력 스마트폰으로 6.1" LCD 터치스크린, 이중 카메라, 그리고 여섯 가지 색상으로 제공합니다. iPhone XR의 후속 제품입니다.
475 질문 전체 보기
iPhone 11 FaceID not working - but EVERYTHING looks fine
Hi there,
I’ve bought iPhone 11 (not Pro) which had cracked display - I’ve updated it form iOS 13.7 to 14.0 - I’ve replaced it with good one but not Apple - I’ve programmed (with iCopy Plus) it to have TrueTone which I have now (but still message it is not genuine Apple) - and I am unable to setup FaceID
Most of the time it is stuck on “Move Lower / Higher” sometimes FaceID not Available - sometimes when trying to set up FaceID it looks like it cannot catch autofocus and gets blurry (when in selfie mode - it never happen).
“Red Light” present (I was able to capture it using other iPhone camera) - selfie photos are sharp - proximity sensor is working - automatic brightness working - I’ve updated to iOS 14.0.1 - same nothing.
Many people reporting they have same problem after iOS 14 - but I do not know if that happen because of iOS 14 as I STUPID done update before replacing LCD.
Please see photos of my sensors
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
Did you replace the selfie camera assembly? On the iPhone X-present, those are NOT user-replaceable with the ability to keep Face ID.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Noup - I did not - and if I would (or someone would) I think I would get "FaceID not working" or something like that - but sometimes I got no message "FaceID not available" for very long time when I try to setup
댓글 달기
I’m having the same issue too, except I haven’t got the “FaceID not available” yet. It just tries to focus over and over, moving in and out of blurriness. It tells me to position my face in the frame, even when I am. Let me know if you get an answer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
use macbook camera to see if you will see faceID "red" blinking light - if yes - it is good thing
댓글 달기
귀하의 답변을 추가하세요
Bart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 467
