주요 콘텐츠로 건너뛰기
다양한 주방용품 수리 안내서 및 지원.
80 질문 전체 보기
Why is my water filter so low?
We have a Profile Reverse Osmosis Water filter in our sink as a water softener. We recently saw a problem with the water speed as the flow rate decreases after a couple seconds to a drip. I was thinking we might have to reset the filter but Im still not sure. Do you guys have any tips to fix this issue? Thanks in advance!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Hi , check to see if the tank is full , if it is and the water flow cuts off chances are that there is a problem with you tank blatter and will need to replace the tank. there is a valve located on the side of the tank and pressure should be around 6-7 pounds. Granted the r o will produce soft product water but if your wanting the whole house water softened a water conditioner softener is the solution, ro is usually used at point of use ex. kitchen sink whereas the softener is a point of entry system servicing the whole home.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Suchit Bandaram 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 69
