주요 콘텐츠로 건너뛰기
A gaming laptop released by Asus with a CD/DVD drive.
20 질문 전체 보기
My ASUS ROG GL552JX laptop can’t power on
My Asus ROG GL552JX (5-6yrs)laptop
can’t turn on after shutting down
when i press power button,  nothing happen so i’ve check my battery and AC adaptor status, it was in good condition and i think it’s bios problem  i tried several ways to fix it
  1. Reset BIOS by disconnect the power supply and battery then press power for 40sec then reconnect to power and try to start —> if my laptop turn on my display showed ROGlogo and black screen and then turn off but actually nothing happen when i press power button
  2. Replace CMOS battery (CR2032 3.0V battery but not ASUS genuine battery)—> my laptop is normally boot to windows10 and shutdown without problem for few attempts but, on the next day my laptop can’t turn on
  3. i tried to reset BIOS again it ‘s work but after turn on and shutdown for few attempts my display stuck at ROG logo and turn off again (on the next day it can’t turned on)
  4. Replace another (CR2032)CMOS battery and same problem as NO.2
Is that the mainboard problem? Or any recommendation for CMOS battery or another way to fix this issue?
Thank for your help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
i believe i had something similar to this on an old AMD machine i have and i suspect that the bios is corrupt
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I try to update my BIOS to the latest version but the problem still the same
Thanks for your comment
댓글 달기
귀하의 답변을 추가하세요
chojowiesy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 578
