MacBook Pro 2015 13" dead
13” Macbook Pro Retina (2015) suddenly died.
I tried every key combination to revive it with no luck.
I unplugged battery cable also what brings it down to potential problem with logic board… MagSafe LED is on while charging.
There was no evident liquid spillage but after having closer look I noticed some green residue looking like a corrosion on a part of motherboard which is close to vents. I realised there could be some minor unnoticed spillage while using macbook on some damp surface.
I cleaned that corrosion with dry paper towel but still no luck. Please see the attached pictures and let me know what other steps can I perform before sending it for a professional repair.
Would cleaning that part with 99% alcohol be helpful?
Update (10/02/2020)
I cleaned the corrosion from the outer site, but it didn't help. I took the motherboard out and noticed there are also corroded bits on the other side of JTAG connector. I've cleaned it all and tried to plug the magsafe but with no luck (fan didn't start spinning). Please look at attached pictures and let me know if you guys have any other ideas? Magsafe diod colour - amber.
좋은 질문 입니까?
What is the MagSafe LED's Color Amber or Green?
Dan 의
amber while charging, turns green after while (when battery fully charged I guess)
Kacper Slonina 의
