usb accessories disabled with QGeem Hub
Hello,
I have a USB hub that worked perfectly before my last software update.
Right now I’m running 10.15.6 (19G2021) and when I plug in the QGeeM (PN: HC0801) hub I’m getting the “USB accessories disabled“
Reset PRAM/NVRAM or Reset SMC does not help.
Any other ideas?
좋은 질문 입니까?
댓글 2개
Does it make a difference which port you use?
Also have you tried another USB-C/Thunderbolt device in the port to see if the issue is strictly with the humbug's Vs the system.
Dan 의
same result for all ports. I have a different hub ( much simpler ) that works.
the thing is that the QGeeM worked till now...
albero 의
