주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
Should MBP 2014 CPU throttle without battery?
Hi there,
I got MBP 2014 which has not genuine Apple battery installed. And with plugged it in it gives SMC error in Diagnostic and it is slow (CPU throttle)
When disconnect battery it is the same “slow” - but should it be “fast”?
Just want to know if battery is the problem as no liquid damage at all.
When run FaceTime it says “to wait as temperature too high” but all sensors in MacFanControl shows around 40C only.
Display is from MBP 2015 - but would that be a problem?
Thank You :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You maybe facing multiple issues here!
Your first issue is within the battery! The battery has sensors your systems thermal management system (part of SMC) depends on. To protect you and your system SMC will lower the CPU’s clocking. If you opened up Activity Monitor you will see the process kernel_task consuming a large quantity of your CPU percentage.
So you do need the battery installed (ideally working and charged). Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기.
You clearly have a second issue here as well!
You appear to be using the wrong display assembly! Your system requires a 2013/14 display assembly Apple P/N 661-8153. It will not work properly with the 2015 display assembly and you could also damage your logic board using the wrong one as the iSight camera is not the same. To add to it the iSight camera unit in the lid has a thermal sensor within it (which is why you are getting “to wait as temperature too high”) and that too will kick SMC into CPU Safe Mode!
Both need to be addressed to get your system working properly!
We still may have a third issue lurking… You made a comment about liquid damage! At some point did you get your system wet or have a spill within the keyboard and/or trackpad areas?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Bart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 458
