주요 콘텐츠로 건너뛰기
In 2002, the third-generation model was introduced which saw the model move further up-market. Planned and developed under BMW ownership the third generation was to share components and systems with the BMW 7 Series.
5 질문 전체 보기
No audio system available? No radio tv I pod no audio system at all?
Hi my Range Rover sport 2012 autobio has no audio available see pics for info. Iv changed the battery recently due to it been sat flat for a while.
also I have tried changing the amp and still nothing. Iv tried disconnecting battery terminals and leaving as reconnecting. The only idea I have left is a software update so I’m hoping someone has an idea. Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hey Aaron, was it all working before the battery going flat?
On the infotainment screen, does it show the volume level'?
If the amp has been replaced then it may need programming to the vehicle which will include it being updated to the latest software level.
Have you been able to get anyone to read the fault codes?
If you have access to wiring diagrams I would suggest checking the powers and grounds to the amp before moving forward.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Aaron Perks 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 10
전체 시간: 445
