주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1200 질문 전체 보기
Bluetooth doesn't work, just forever spinning
Hi iFixit,
I recently repaired the screen of a broken iPhone X using your site, super helpful! The only thing that doesn’t seem to work now is the bluetooth, as it’s just stuck spinning. I’ve tried everything to fix it, but I think it’s a hardware issue.
I bought the top right bluetooth flex to see if replacing that would solve it, but I can’t find instructions for it anywhere. Please can you point me in the right direction?
If that doesn’t work, then I imagine it’s a motherboard soldering problem. Any idea where I could get instructions for that also, as this will be my first time doing it.
Appeciate any help!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hi Carlo.
Have you tried resetting your network settings? If not, try that first.
The WiFi/Bluetooth antenna is located under the front camera, see this link at step 11:
iPhone X Disassembly
Before doing anything try to reconnect the flex cable and see if it fixed your issue.
If this is your first time doing iphone logic board level repair I'd highly advise you not to. The components in question are microscopical.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you so much for the quick response. I will give this a go and let you know how I get on.
Cheers!
댓글 달기
귀하의 답변을 추가하세요
Carlo Milillo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 222
