주요 콘텐츠로 건너뛰기
The Volvo XC90 is a mid-size luxury crossover SUV manufactured by Volvo since 2002 and now is in its second generation.
16 질문 전체 보기
Why is my SUV chugging in idle?
My SUV keeps chugging when coming to a stop and idling. It is fine while I’m driving. The rpm gauge jumps up and down slightly in idle as well. I was told to use Mystery Motor Oil. Any suggestions? Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Any engine light or codes? Sometimes the coil packs get wonky and only work when the cpu asks for higher rpms. Used to own many volvos and fixed them regularly.
@caleymac what exact year and engine size is your Volvo? Besides "Mystery Motor Oil, what have you tried? How is your gas mileage? Has it gone up drastically? How is the performance when not at idle?
댓글 달기
답변 2개
가장 유용한 답변
Rough idling can be caused by clogged filters. ... Bad spark plugs, bad spark plug wires and a bad distributor cap are other common causes of rough idling. These items are all important parts of what keeps a vehicle running. Spark plugs provide the spark that ignites the air and fuel mixture within the cylinders.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It’s the throttle body dirty I had mine like that even at a stop sign shuts off . Took it off and cleaned it with throttle body cleaner from autozone now it idles like brand new
xC90 2006
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
That makes sense. It wouldn't trip a code either.
댓글 달기
귀하의 답변을 추가하세요
CaleyMac 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 8
30일 전: 18
전체 시간: 749
