주요 콘텐츠로 건너뛰기
2017년 11월 4일 출시. A1865, A1901. GSM 또는 CDMA / 64 또는 256 GB / 은색 또는 스페이스 그레이. ("iPhone 10"으로 발음합니다.)
1199 질문 전체 보기
Why does my iPhone keep randomly switching off?
I have this problem with my iPhone X where throughout the day, even at say 53% battery left, it randomly switches itself off. I wouldn’t mind so much if I could just switch it back on but the issue is that I can’t switch it back on by it’s own power, it has to be plugged into a power source, whether it be a PC or by a plug socket. Any ideas what might be causing this issue? I had thought of possible a faulty battery connector but if I switch it off normally and then switch it on normally it’s fine. Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
I would take a look at the maximum capacity in the battery health tab. Typically when it gets below 85% is when I recommend a replacement as that’s roughly when people notice battery trouble. But it could be an issue with the port as well. The iPhone X and above are picky when it comes to charging ports. If it’s not connected, functioning properly, or it was replaced with an aftermarket port, it can cause issues like this.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brandon Frost 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 40
