주요 콘텐츠로 건너뛰기
2018년 3월에 출시된 Apple iPad 6의 Wi-Fi 전용 버전입니다. 32GB 및 128GB 스토리지 옵션으로 제공됩니다. 9.7인치 레티나 디스플레이와 64비트 A10 퓨전 칩이 특징입니다.
151 질문 전체 보기
Full screen static after display replacement
Anyone seen this before? It’s new to me.
The entire screen is scrambled gray and rapidly flashes about half of the screen as shown in the screenshot from a video I took. This is the second display from the same vendor that I’ve installed in this ipad and both produce this static-like image. If I re-install the broken LCD, I can see the image clearly (as clear as possible on a broken display). There are no signs of static on the original.
I’m concerned that I’ve received two defective replacement panels, but it feels unlikely. Again, I’ve never seen this behavior before in a replacement panel.
Any ideas or thoughts? Thanks!
Edit: I forgot to mention that I did see one similar post from searching and they were successful by performing a DFU reset. I went ahead and tried it, but the issue persists.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Apparently, I cannot read. The LCD panel I was using as a replacement was for A1823 and I’m working on an A1893. Whoops!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
When you close the screen use a cloth to remove static but this may not resolve the issue if the LCD you got is broken.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Christopher Stout 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 8
전체 시간: 175
