주요 콘텐츠로 건너뛰기
2018년 3월에 출시된 Apple iPad 6의 Wi-Fi 전용 버전입니다. 32GB 및 128GB 스토리지 옵션으로 제공됩니다. 9.7인치 레티나 디스플레이와 64비트 A10 퓨전 칩이 특징입니다.
151 질문 전체 보기
LCD showing multiple of the same image after rebuild
I was fixing a broken screen/digitizer on a 6th gen iPad and now have issues with the LCD after rebuilding it. Your guide was great. Minus dealing with the broken glass, I had no major issues disassembling the iPad and the reassembly was easy. Things went wrong though when I turned the iPad back on to check to see if the new screen worked. The LCD was now showing multiple of the same image. There’s also a white bar near the top of the screen. I’ve attached a photo so you can see what I’m talking about. I was super careful with the LCD when I removed it and don’t recall bending it or putting any other significant force on it… however, I’m not ruling out that maybe I did. Is my LCD hosed or is there something else I can try to fix it? Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Take it apart and inspect the display connectors and cables for damage. By the looks of it you did leave a few fingerprints on the LCD but that’s not a huge issue as you can gently wipe them off. Anyways if the connectors look good I would try another LCD. If a new LCD still shows the same problem them you’ve probably got a board issue on your hands and it will need to be repaired by a microsoldering specialist. Did you make sure to disconnect the battery and put something under the board between the battery before disconnecting the screen?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Connectors and cables look good. I did disconnect the battery as shown in the guide. I will try a new LCD and see if that works. Thanks.
댓글 달기
귀하의 답변을 추가하세요
Ryan Glaske 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 40
