주요 콘텐츠로 건너뛰기
동일한 모델 번호(A1932)와 EMC 번호(3184)를 사용하는 2018년 후반 MacBook Air의 소규모 개선에 대한 수리 정보 및 안내서입니다. 이 모델은 트루 톤 디스플레이와 약간 수정된 배터리가 특징입니다.
101 질문 전체 보기
How to turn on my MacBook Air without using power button? - Docking
Hi,
This is NOT about broken power button or such. My Macbook is working fine. I am planning to have my MacBook connected to 2 external display (24 inch monitor). However I would like to close the Macbook itself and put in on the stand. My question is how can I turn on my Macbook without have to take it out from the stand?
I am looking for a stand like the one below:
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Sadly there just isn’t any way to start the system without physically touching the power button.
Why don’t you look at a pair of VESA mounts for your displays so you can swing the displays to the side to gain access to your system which is flat on your desk.
In any case I do think you’ll need to get your system repaired so the power button works correctly.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Do you have link or photo of the mount?
댓글 달기
How to restart
On your Mac, do any of the following:
1.Choose Apple menu > Restart.
2.Press and hold the power button until you see options, then click Restart or press R (or use the Touch Bar).
3.If the pointer freezes on the screen or your Mac becomes unresponsive, press and hold Control-Command while you press the power button to force a restart.
Important: If you force a restart, you may lose unsaved changes in open documents.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
@sanjeev9910 - This doesn't answer the question asked.
please don't grind rep by posting unrelated answer :(
댓글 달기
귀하의 답변을 추가하세요
Lai Soon Chong 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 16
30일 전: 19
전체 시간: 599
