power button stop working after smc reset
I did a smc reset because the fan was spinning at maximum. After that the power button does not turn on the computer, it makes the same combination of lights on the charger as when the smc reset is done. In order to turn on the computer I have to disconnect the battery and charger and then reconnect the charger. But when you press the power button again it shuts down directly. Excuse my English, I'm using an automatic translator. Cheers
좋은 질문 입니까?
Your systems SMC logic has latched its self in a failed condition as it thinks there is something very wrong with your system.
After restarting your system press the D key to enter into diagnostics. Let us know what the error message you got.
Reference: Mac startup key combinations
Dan 의
already checked de diagnostics, all ok
Dario Nicolas Garcia Colombo 의
OK, then you'll need to check your battery, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 기존 질문에 이미지 추가하기
Dan 의
i have the battery desconected, and i've already tested 2 batteries
Then the logic board has a problem diagnostics doesn't check. I find that hard to believe. Maybe you have bad batteries.
Did you have a liquid spill at some point which got into the keyboard or logic board?
Dan 의
댓글 3개 더보기
