주요 콘텐츠로 건너뛰기
{A1706 / EMC 3071}—2017년 6월 출시, 이 MacBook Pro 13”는 Kaby Lake 프로세서 최대 3.5 GHz Core i7 및 Turbo Boost 최대 4.0 GHz 포함.
276 질문 전체 보기
Touch ID Dont work after toucBar repair
Hi .I droped my mac .After 1 month and a lot of problems trying to use it without touchbar (restarted ) i read same information and manage to to the repair with a local technician .The problem is we manage to change touchbar but now touch id dont work .It said tha i have to delete some fingers and it wont show any. When i click down the marks it will load tha registration page but wont let insert any.The messege is try again .I tried software solutions. Is there any case this is on purpose for safety reason ?Thanks .Keep up the good work :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Did you replace the Power/TouchID button as well?
No .It worked before repair
댓글 달기
답변 2개
선택된 답변
If the power button was replaced during the repair then it won’t work. Biometric verification components such as TouchID and FaceID in apple products are tied to that specific device. Even if you purchased a brand new machine from apple and swapped the parts between the two, you would lose TouchID without the use of a special calibration tool that only apple and their service providers have. If the button was not replaced, it could’ve been damaged by the technician or it may not be connected properly.
Unfortunately apple does not like independent repair shops working on their devices because it effects their bottom line, but that is no way, any consumers problem. Apple has reached a net worth of 2 Trillion dollars, and they certainly didn’t do that by being honest or helpful to their consumers.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
peris93 - You’ll need to bring your system into Apple sadly for them to fix this. You’ll also need to bring proof of purchase and a photo ID that matches the invoice.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
What is the point of doing that?
I know my passwords and I have access everywhere but not with the fingerprint.
@peris93 - If you want the TouchID to work you'll need Apple to fix it! Yes, you can still get into your system using the login/password.
Its just a matter of what you are willing to live with or in this case without!
댓글 달기
귀하의 답변을 추가하세요
peris93 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 660
