주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
Diagnosis code PPF003 question
My fans is running constantly. The diagnostic code is PPF003. Apple advise that it is a fan issue and that it should be taken to a service center. But surely it’s the thing that switches the fan on and off that’s the issue. I have reset the SMC. I don’t want to replace the fan only to find that the new fan runs constantly. Any suggestions/comments?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Within the fan is a tachometer to monitor the fan’s RPM (feedback) that way the SMC logic can make sure to set the fan as the correct cooling level needed.
The error PPF003 really doesn’t tell us if the fan its self or the controlling logic is the problem. The easiest way is just replace the fan to see if that solves the problem or not. MacBook Air 13" (Late 2010-2017) Fan and here’s there guide to put it in MacBook Air 13" Mid 2013 Fan Replacement.
I would first get a soft paint brush and a can of can’ed air to clean the dust and debris thats collected inside out. Your fan may every come back to life! You may want to use a better way to monitor your systems thermals, I like this tool TG Pro
MacBook Air 13" (Late 2010-2017) Fan 이미지
상품
$29.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I cleaned the fan. I replaced the fan with a new one. Still the fan runs at full speed. I installed TPPro - no temperature issues. I ran ASD EFI software. “sensor - voltage (VPOR) — PBus reading below limit” No other sensor issues. Where is this sensor - anyone know?
댓글 달기
귀하의 답변을 추가하세요
Peter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 482
