Why is my fan is always running at 7200RPM
My macbook fan is always running at 7000-7200 RPM. From the moment, I press the power button, it starts running very loud, and stays the same. It doesn’t matter what I am doing, it always stays around 7100RPM. I’ve reset de PRAM and the SMC. I’ve installed Fanny and it says:
Fan: #1
Current: 7104 RPM
Min: 1200 RPM
Max: 6500 RPM
Target: 1200 RPM
CPU: 34.75 degrees celcius
GPU: 36.00 degrees celcius
Please help me fix it, the sound of 7200RPM is very loud and annoying.
Update (11/04/2020)
Here is the screenshot.
https://pasteboard.co/JyPPvth.jpg
Please let me know if it doesn't work
좋은 질문 입니까?
Did you try running the onboard diagnostics to see if an error code? Restart the system and press the D key to enter. Tell us what it is.
Reference: Mac startup key combinations
Dan 의
@danj Thanks for your help. I have already tried that and nothing comes up.
Tom 의
To be clear you don't get any errors Or it doesn't work?
Dan 의
Pardon me, I don't get any errors. Sidenote: I've already replaced the thermal paste and cleaned the fans thoroughly.
Tom 의
OK, lets do this, kill Fanny and install this app TG Pro it will offer a better view of the thermal sensors.
Dan 의
댓글 2개 더보기
