주요 콘텐츠로 건너뛰기
모델명 A1707. 2017년 6월 출시, 이 MacBook Pro는 Kaby Lake 프로세서 최대 2.8 GHz 쿼드코어 Intel Core i7 프로세서와 Turbo Boost 최대 3.8 GHz를 사용합니다.
327 질문 전체 보기
Bootloop after Install Mojave, cannot Recovery or anything
Hello and I ask for help,
MBP 15” touchbar 2017, in normal use with Sierra, update to 10.14.6, after a week normal use and when to sleep, it turn off and got in to bootloop, I even tried do something but cant help:
- Bootloop at normal startup or auto turn off at process startup bar.
- Bootloop at recovery mode, internet recovery, shift mode (or auto turn off)
- Same as Mojave usb installer
- Same as Time machine backup from external drive.
- Sierra usb installer show as Folder and emty logo when chose, then turn off.
- Catallia usb installer show “You compurter restart because of a problem…” with many language.
- Use D, it runs fast (i dont think it took 3mins, just about 10–15secs) and show that No problem.
- Use CMD+S, as this picture, I think there something happened with system drive.
- Reset vram, pram… no help
Hope for help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Did you buy this as a new system or was it bought used?
@danj I bought it 3 years ago as new with Sierra OS installed.
댓글 달기
답변 2개
선택된 답변
It sounds like the logic board has failed. I was thinking this was a bricked system as it does appear the logic board has been iCloud locked.
Best to get your system to an Apple Store for them to fix this.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Seem it must be serious!
댓글 달기
timestamp indicate it need to reset the clock appropriately, if you are able to go to the BIOS (f1, f10) and reset the time zone, it may resolve the problem, it is recommended that you find someone who can help you using the BIOS configuration. That is a sensitive area of the computer, needs an experienced IT.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Thank you for your infomation, let me check it out
As I researched, macbook doesnt have BIOS, right?
댓글 달기
귀하의 답변을 추가하세요
NiNi72 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 81
