주요 콘텐츠로 건너뛰기
iRobot's Roomba 980 automated vacuum cleaner. Released on September 2015.
16 질문 전체 보기
Keeps throwing a code 2 to empty trash
Keeps saying to empty trash but there is no trash in it
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Error 2 on an iRobot Roomba 980 usually means that the rubber brushes are clogged and need to be cleaned. The most likely cause is hair stuck on the brushes, which is preventing them from spinning properly.
To fix the error, you can try these steps:
  1. Clear the brushes
  2. Pull the extractors out, clean any debris/hair on the ends, and pull the yellow end caps off
  3. Press the CLEAN button to restart
If the Side Brush is not spinning after cleaning, you may need a replacement Side Brush Module.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Strain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 123
